Networked Calypso not Updating with Program Changes
Hey All,
I'm relatively new to the Calypso programming world and I have been having a few issues with Autorun on four networked CMMs. I load a program from the network drive in Calypso on CMM A, alter a feature or characteristic, save it to the network and then use the Autorun program on the same CMM. It runs and reports flawlessly. If I try to load the Autorun on CMM B, which loads the program file from the same location, it does not recognize the program change and doesn't output the new characteristic. If I close Autorun, manually load the updated program from the network on CMM B, the new characteristic shows up in the program. I can close it, start Autorun, and now it runs and reports as expected. Is this something I will have to do each time I update a program? Or is there an easier way that I am missing?
