Problem with Calypso remembering inspection path.
My new machine is running 7.0 with latest patch. It does not remember to go to inspection folder when I open program folder icon.
Path under extras-settings-environment is correct. Whatever folder I handled last is where it goes. If it was userinfo then that's what it opens.
This happened before when I went from 6.2 to 6.4 but I can't remember how I resolved it.
Any ideas?
If you have the "default path for measurement plans" set under "Extras- settings-environment", then that is what should open when you click on file-open. If you click on file open, and navigate to a different location, then that different location is what will open the next time you click on file open. Chances are that your programs are arranged in folders by customer name or something.
I had this happen to me once, if I remember correctly I typed in the address to my program library in the top bar of the window.
  • 1 month later...
So I had Zeiss log into the machine. The tech said that I had everything setup right and that it looked like a bug. He would get back to me. That was nearly 2 weeks ago. I've since "fixed" it by putting my mapped drive into the inspection path. Some how Calypso likes that. I won't argue.
