[Ry...] Posted April 1, 2021 Share Posted April 1, 2021 Good Morning Everyone, So I made quick mistake and forgot to click the button to save all my PiWeb PDF reports to the file folder, after I ran the final inspection batch. Our customer requires these reports from our sampling plan. So my question is, is there a way to recall the PDF report? I only have the basic PiWeb version, and have the last 10 part results stored in the PiWeb Database, but how do I get those results to print back out into the standard PDF format? Thanks for you help, Ryan Link to comment https://qualityforum.zeiss.com/topic/13220-how-to-recall-a-piweb-report-in-pdf/ Share on other sites More sharing options...
[e3...] Posted April 1, 2021 Share Posted April 1, 2021 Please sign in to view this quote. Hi Ryan, When you have the report open, hit F6 to open the Measurement Selection pane. Expand the selection to last 10 measurements. Then click on the 'Single Measurements' button and find the measurement that you want to repopulate the report. Press OK. Go to File > Print > Print to PDF. Link to comment https://qualityforum.zeiss.com/topic/13220-how-to-recall-a-piweb-report-in-pdf/#findComment-67144 Share on other sites More sharing options...
[Ri...] Posted April 1, 2021 Share Posted April 1, 2021 This is also a good time to have the Measuring Points inside of Calypso turned on. Link to comment https://qualityforum.zeiss.com/topic/13220-how-to-recall-a-piweb-report-in-pdf/#findComment-67146 Share on other sites More sharing options...
