problem coordinate system
Hello all,
I have a question to coordinate systems
My problem. I create a coordinate system as a base system, on this basis I measure a curve,
In evaluating the curve, I create the coordinate system WP_TCapto_bestfit_1 (*) of the curve as the basis for further measurements.
Furthermore, I create a coordinate system Koord.-System2, based on the WP_TCapto_bestfit_1 (*) (see picture), however without Planar Rotation.
[img][/img]
My question, do I absolutely have to define the Planar Rotation ?
Some colleagues say yes, because otherwise the value of the base system is used as the Planar Rotation. That would not be correct !!!
Other colleagues say if I define a new coordinate system, I have to define the Rotation in Space and also I must define the Planar Rotation.
Or I can leave the Planar Rotation field “blank” with the background that in my case the value Planer Rotation of WP_TCapto_bestfit_1 (*) still applies for the Koord.-System2.
I'm confused, what is correct ?
Based on the picture shown, Koord.-System2 will use the spatial rotation from WP_TCapto_bestfit_1, since that's what's selected in the dropdown beside the "comment" button.
Planar Rotation is not always needed and can be left blank. This is very common on turned parts with no clocking features. It doesn't matter how I place the part on the fixture to measure it I will get the same answer. If you wrote a program for a plug gage it would be a Cylinder and and a Plane for the Base Alignment.
Spatial Rotation (Rotation in Space for Calypso 2020) - Cylinder
Planar Rotation - BLANK
X Origin - Cylinder
Y Origin - Plane
Z Origin - Cylinder
