Calypso 2020,,, thoughts?
I have used it for a few training classes.
They fixed the 3d line error bug and the new patched fixed the issue in simulation where it would show the whole machine or the Stylus/Machine buttons where not active.
Haven't noticed the Caliper Distance bug
PiWeb seems faster with the new extension type, remember you need to convert old data bases to the new format.
  • 3 weeks later...
I don't know if its just me, but I've been running it for about a month now and noticed that I cannot run in CNC manually.
What I mean is I create a feature, and want to run that feature right away with position points only. It keeps bringing up an error. In order to check that feature, I have to have a full base alignment and clearance planes set before I can run that feature.
In previous versions I ran position points all the time while dialing in a probe strategy of a feature. Now it wont let me.
Anyone else?
Thanks,
Ryan
We have 2 Prismos and a Duramax, and in the last two weeks have upgraded to Calypso 2020.
We are having an issue with the CMM stopping in mid air and freezing, no Red Light, just won't move. This has happened on both Prismos, not the DuraMax, and only since we upgraded.
Has anyone else had these kind of issues?
Have it happening occasionally in 2019, not so far in 2020. Micuras. Seems to have "taken care of itself" 😱 😱
The caliper issue was resolved with latest service pack. I am finding that Pi-web is actually taking longer to load and print after running programs than it was in previous version.
Hopefully that works for a section cut by connecting all the cut lines. Picking model edges isn't my "go to" for creating curves, as you still need to offset the curve off of the edge and doesn't always capture the geometry you want to measure anyway.
On the subject of curves... did they ever add the ability to paintbrush curve tolerances curve to curve? Never understood the inability to do that.
Used it for about 2 weeks. So far it seems to have fixed several flaws from 6.6 that we were running. Much faster with CAD models.
