[Ra...] Posted March 22, 2021 Share Posted March 22, 2021 After research I found a tutorial that shows you can save a inspection by using resource, compatibility setting, for this measurement , performance as if created with Rev. This should allow you to save to a older version. I am running a version 7.0.02 and my co workers are using 6.8. They are getting the following error. Can someone please provide any type of information or direct me . Thank you guys.1.jpg Link to comment https://qualityforum.zeiss.com/topic/13280-question-regarding-compatibility-version-68-vs-7002/ Share on other sites More sharing options...
[Ra...] Posted March 23, 2021 Author Share Posted March 23, 2021 You have the do the above. Then you have to edit the version txt file in the inspection folder. Change that to the version that is being used as well. So if you want to use your inspection on a 6.8 version. Save it using resource,compability setting etc. to the 6.8 version.(Back Saving) Then you need to edit the txt file called "version" and change it to 6.8 😃 Link to comment https://qualityforum.zeiss.com/topic/13280-question-regarding-compatibility-version-68-vs-7002/#findComment-67506 Share on other sites More sharing options...
