[Fl...] Posted December 16, 2020 Share Posted December 16, 2020 I have one diameter and the client want two characteristic for this diameter (with Min and Max) . It is possible ,with one measurment and how because i can put the evaluation only in Features? thanks Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/ Share on other sites More sharing options...
[Da...] Posted December 16, 2020 Share Posted December 16, 2020 Florin, your customer probably wants Local 2 Point diameter (LP) if drawings are ISO. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67620 Share on other sites More sharing options...
[Fl...] Posted December 16, 2020 Author Share Posted December 16, 2020 Thank you Dane for explication, my client have in the drawing Envelope conditions. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67622 Share on other sites More sharing options...
[Mi...] Posted December 16, 2020 Share Posted December 16, 2020 Make another circle using "recall feature points" from the first, then give it its own evaluation setting. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67624 Share on other sites More sharing options...
[Ri...] Posted December 16, 2020 Share Posted December 16, 2020 The evaluation is done at the Characteristic side. You can have one feature that is attached to multiple Characteristics. Create the Characteristic, add the feature, right click on the feature and set the appropriate evaluation you are looking for. Also, the 2-point diameter (LP) is not the same as MIC/MCC. The Local-Point diameter is showing you the max/min two opposing points. The MIC/MCC is showing you a circle created from the 3 outer/inner points. The MIC/MCC is the functional size. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67626 Share on other sites More sharing options...
[Da...] Posted March 10, 2021 Share Posted March 10, 2021 Hello everyone, I also have an envelope problem. My client asks me for the envelope but on Calypso 2014 I can't find it. I know it should be in the 2 point diameter but I honestly can't figure it out. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67628 Share on other sites More sharing options...
[To...] Posted March 10, 2021 Share Posted March 10, 2021 Please sign in to view this quote. You can make multiple diameter characteristics and change the evaluations within them. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67630 Share on other sites More sharing options...
[Er...] Posted March 13, 2021 Share Posted March 13, 2021 Try "extended position" to "on" under Characteristic Editor. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67632 Share on other sites More sharing options...
[Da...] Posted March 13, 2021 Share Posted March 13, 2021 I don’t get it. Choosing the Envelope condition in the 2-point-diameter gives you two evaluations: the Maximum Material envelope diameter and the two-point least diameter (for a hole). That is the max and min your customer wants. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67634 Share on other sites More sharing options...
[Ma...] Posted March 16, 2021 Share Posted March 16, 2021 For this wouldn't you just pick the diameter characteristic, and then select the scanned circle, and under evaluation select maximum inscribed element? Then do the same just changing it to minimum? Why is the 2 point diameter being utilized? Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67636 Share on other sites More sharing options...
[Ma...] Posted March 17, 2021 Share Posted March 17, 2021 Please sign in to view this quote. Because right or wrong, there may be no place on the part that the diameter could be measured that would equal the inner or outer tangential circle. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67638 Share on other sites More sharing options...
[Ma...] Posted March 17, 2021 Share Posted March 17, 2021 Oh okay, I understand now. I didn't even think of that. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67640 Share on other sites More sharing options...
[Me...] Posted March 17, 2021 Share Posted March 17, 2021 Please sign in to view this quote. I still am not quite understanding the purpose, can someone give an example of a situation where this is useful? It seems useful but I'm not comprehending at the moment. Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67642 Share on other sites More sharing options...
[Ma...] Posted March 17, 2021 Share Posted March 17, 2021 For ISO size use two point diameter with envelope condition (Outer tangential) for max material. This should also satisfy rule one of Y14.5 shouldn't it? Link to comment https://qualityforum.zeiss.com/topic/13300-minimum-circumscribed-element-max-inscribed-element/#findComment-67644 Share on other sites More sharing options...
