Inspection File deleted
Good Morning Everyone,
We were messing with moving over files and accidentally deleted the Inspection file from a program's folder. The program has been used for months now. Everything else is inside that folder except for the inspection file.
Is there any workaround that will let Calypso regenerate the program using everything in the folder?
Since the program was in the network, it wasnt sent to the recycle bin.
is there any way to save this without having to create it again?
Thank You,
Nixon U.
Restore that program folder to a previous version. If you have an IT department or person they'll be able to fix it no problem. Unless you have administrators rights and can do it yourself.
Sadly I've made this mistake countless times due to my fast clicking bad habits.
I've tried doing that but there is no backup of previous folders.
I am assuming they never turned on backup option.
Salvaging an inspection plan without the inspection file is essentially the same as a person being brought into the hospital only missing the brain, all internal organs and the skeleton.
"Can you heal him, doctor?"
If IT is not backing up files on the server, it is the first time I've heard of a server that is not backed up as a whole.
I would be tempted to gently bump this up with an IT ticket. This needs to be fixed.
