[Ji...] Posted March 10, 2021 Share Posted March 10, 2021 I have taken a cad model and produced a curve out of three sections(a line 6 degree from center line, a .200 radius and a line 6 degrees from center line). Simple enough I thought. When you run the part it comes out showing everything to be in the tolerance band and following the nominal band fairly close. Then you put a part on that is known bad and it still follows the nominal line and is well within the tolerance band. The .200" radius is closer to .400" radius but the curve profile is showing it to be well within the band and you can not tell a notable difference in the angles or radius. I know it is not going to give me a great reading on the radius as it is only .080" across it. I would expect it to show the shape out of the tolerance band though. Link to comment https://qualityforum.zeiss.com/topic/13318-curve-issue/ Share on other sites More sharing options...
[Da...] Posted March 11, 2021 Share Posted March 11, 2021 Can you make a quick sketch with a few dimensions? Link to comment https://qualityforum.zeiss.com/topic/13318-curve-issue/#findComment-67778 Share on other sites More sharing options...
