Angles exported to Excel.
I am reporting angles on the Custom Report in Deg. Min. Sec; for some reason PiWeb defaults the reporting to Radians; and I don't know what the Excel values represent
E.g.
Custom Report = 9 Deg 50min 46 sec
Pi-Web = 0.1718
Excel = 0.410
What is Excel reporting, and how can I convert it into DMS or Radians?
You also should be able to change PiWeb to read in Radians or Decimal Degrees. Inside your PiWeb Reporting Template: Tools - Settings - Output unit of measured angles.
  • 10 months later...
I don't know how many of you use the Curve Slope Characteristic, but it ONLY reports in Radians. You have to create a Result Element to convert it to Decimal Degrees. So frustrating. I have NEVER seen a drawing in Radians.
