[Je...] Posted March 5, 2021 Share Posted March 5, 2021 I extracted points thru CAD/ extract / point and now they are in features. How do i change the stylus position between each point feature? Example : In a circle feature their is a drop down for the different stylus in strategy. Link to comment Share on other sites More sharing options...
[Ja...] Posted March 5, 2021 Share Posted March 5, 2021 feature > strategy > click on any probing point to open "point list" menu > on top click "stylus" (highlighted blue in the pic) . here you can select "stylus" for each point (click on any stylus and you will see a drop down menu to select desired stylus. Make sure to use "position points" between each stylus position change appropriately to avoid collisions during run. see attached pic. contribution_3_5_21.pngFetching info... Link to comment Share on other sites More sharing options...
[Je...] Posted March 5, 2021 Author Share Posted March 5, 2021 Thank you, my button says "special data" instead of stylus. but the rest was the same Link to comment Share on other sites More sharing options...
