Iam at my wit's end
So datum targets for -A- and -B- are cast surfaces. Gee wiz. This is nuts.
Is there a hard fixture? It may give insight to what the customer wants.
From what i can see...
-A- would constrain YZ
-B- would constrain X and spatial
The Dim 30 hole from -A- constrains planar?
-A- would almost have to be made from 3 lines with the points recalled into a maximum inscribed circle.
Without a cross section of -B- it's hard to make out what it is.
Educated guess says this is a hub for a fan blade. Balance would be important.
Good luck.
Use your |A| datum targets to create a theoretical plane and your |B| targets to create a circle. Level to |A| and originate from |B| (no planar / clocking.) Now, report your runout to that alignment. Runout, in this case, is controlling the orientation of the surface to |A|.
If the Datum Targets for -B- are holes (tough to see in the picture but makes sense for the callout), you measure the three diameters and create a circle from the three holes for Datum B (use recall).
If you are using any version of Calypso that is not 2020 you will have to Construct / Perpendicular and pick Datum B and then Datum A and use that to evaluate runout to A and B, because before 2020 only 1 datum feature is allowed for runout.
