[SH...] Posted February 24, 2021 Share Posted February 24, 2021 I have no idea, how to measure this runout inside the red mark. Datums are casting surface and complicated datum target....IMG_20210224_204347.jpg Link to comment Share on other sites More sharing options...
[Da...] Posted February 24, 2021 Share Posted February 24, 2021 What geometry are A1 to A3? Planes? Almost certainly there is something wrong with this runout callout. Link to comment Share on other sites More sharing options...
[SH...] Posted February 24, 2021 Author Share Posted February 24, 2021 Three planes, one datum target on each plane. Link to comment Share on other sites More sharing options...
[Mi...] Posted February 24, 2021 Share Posted February 24, 2021 Radial runout, to two parallel planes? Definitely get in touch with the customer. Link to comment Share on other sites More sharing options...
[Er...] Posted February 24, 2021 Share Posted February 24, 2021 So datum targets for -A- and -B- are cast surfaces. Gee wiz. This is nuts. Is there a hard fixture? It may give insight to what the customer wants. From what i can see... -A- would constrain YZ -B- would constrain X and spatial The Dim 30 hole from -A- constrains planar? -A- would almost have to be made from 3 lines with the points recalled into a maximum inscribed circle. Without a cross section of -B- it's hard to make out what it is. Educated guess says this is a hub for a fan blade. Balance would be important. Good luck. Link to comment Share on other sites More sharing options...
[Ja...] Posted February 25, 2021 Share Posted February 25, 2021 Use your |A| datum targets to create a theoretical plane and your |B| targets to create a circle. Level to |A| and originate from |B| (no planar / clocking.) Now, report your runout to that alignment. Runout, in this case, is controlling the orientation of the surface to |A|. Link to comment Share on other sites More sharing options...
[Ke...] Posted February 25, 2021 Share Posted February 25, 2021 Are you using the datum targets for your base alignment? If so, you may want to use something that is more robust. Link to comment Share on other sites More sharing options...
[Te...] Posted March 1, 2021 Share Posted March 1, 2021 If the Datum Targets for -B- are holes (tough to see in the picture but makes sense for the callout), you measure the three diameters and create a circle from the three holes for Datum B (use recall). If you are using any version of Calypso that is not 2020 you will have to Construct / Perpendicular and pick Datum B and then Datum A and use that to evaluate runout to A and B, because before 2020 only 1 datum feature is allowed for runout. Link to comment Share on other sites More sharing options...
