Compound angle
The angle callout between each tooth is 60° ± 2.0° The problem is that
each plane is at a compound angle, so how do I evaluate angle accurately
plane to plane when both are at a compound angle?
It's hard for me to tell what angle you're interested in measuring. Is it the tooth-to-tooth 60° angle? Or from one side to the other of the same tooth? If it's the first one, just use a symmetry constructions, but the second is more complicated.
Generally, though, for compound angles I'd say intersect with a theoretical plane to get two lines, then measure angle between those.
I was thinking of something similar. There is a vertical OD cylinder below the teeth.
I could intersect each plane with the cylinder and use those for the angle between.
How about:
- symmetry plane construction between the two planes
- secondary alignment. ID (or OD) cylinder for spatial rotation and origin, symmetry plane for planar rotation
- Result Element that calculates Plane1.A1+Plane2.A1
Angle Between Features (From and Location / Angle Between Features)should work if you are looking for the compound angle
If you are looking for a 2d angle you need to project them to a common plane (real or theoretical)
