Circle, line and circle forming a curve?
Hi,
I'm trying to make a circle, a line and a circle form a curve, to be used for a Line Profile tolerance. The part isn't equal to paperdrawing, since the circle radii is off, on the part I'm program from.
So I sectioned the body, and derived the circles and the line, edited the nominals and now i want the three entities to form a Curve, to be used for a Line Profile talerance charateristic. Tried recalling points, but get an odd result..
See attached picture: blue line is the parts I want to connect, yellow is part nominals
Any help is appreciated!
Thank you
- Johan
https://qualityforum.zeiss.com/topic/13430-circle-line-and-circle-forming-a-curve/
It sounds like you've sectioned the model but haven't created the curve feature yet?
Open CAD->Creating Features. Then, in wireframe view, hole CTRL+select the three segments you want to combine into a curve, define the number of nominal points you want in the dialog box, then click the "curve" button.
