[Jo...] Posted February 25, 2021 Share Posted February 25, 2021 Hi, I'm trying to make a circle, a line and a circle form a curve, to be used for a Line Profile tolerance. The part isn't equal to paperdrawing, since the circle radii is off, on the part I'm program from. So I sectioned the body, and derived the circles and the line, edited the nominals and now i want the three entities to form a Curve, to be used for a Line Profile talerance charateristic. Tried recalling points, but get an odd result.. See attached picture: blue line is the parts I want to connect, yellow is part nominals Any help is appreciated! Thank you - Johancalypso 1.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted February 25, 2021 Share Posted February 25, 2021 Just create strategy on those three elements and recall points with recalculate on new curve. Just don't recalculate it with measured data. Link to comment Share on other sites More sharing options...
[Jo...] Posted February 25, 2021 Author Share Posted February 25, 2021 Gives me this odd result? Or am I doing somthing wrong?calypso 2.jpg Link to comment Share on other sites More sharing options...
[Ow...] Posted February 25, 2021 Share Posted February 25, 2021 Maybe I'm misunderstanding what you're trying to do but, for lack of replies, I'll try. When you create feature circle, 2D line, circle off of the section, why don't you just create a curve from the section in the cad-entity creation tab? Link to comment Share on other sites More sharing options...
[Mi...] Posted February 25, 2021 Share Posted February 25, 2021 Please sign in to view this quote. It sounds like you've sectioned the model but haven't created the curve feature yet? Open CAD->Creating Features. Then, in wireframe view, hole CTRL+select the three segments you want to combine into a curve, define the number of nominal points you want in the dialog box, then click the "curve" button. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 25, 2021 Share Posted February 25, 2021 Please sign in to view this quote. This is happening when circles are rotated. Set rotation angle to zero and adjust strategy path. Then you can correct vectors. Link to comment Share on other sites More sharing options...
