Slot
Hello to everyone,
How can I create the half slot below. I am getting incalculable when I define it with dots. Whatever I tried I could not succeed. I have to make a position query in this slot.
I can create a circle from a slot radius, or I can theoretically create a circle from slot planes. I adjusted my schedule accordingly. But I think it would be better to use all surfaces since the tolerance is 0.05mm.
Thanks
Without the second radius, I don't think you can call out a slot. What I think I would try is probe the radius as a circle, then a second circle around the OD of the part. Then make a line on either side. Intersect the lines with the OD circle, then get the center point between those two intersections. You should be able to make a 3d line from that center point and the smaller radius to check any angle.
I created a circle using planes.
I made an intersection between planes and forehead.
I created a symmetry plane.
When the part is started to be produced, I will compare it with the measurement.
