Profile Datum Structure
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
    19
    17
    14
    6
Ohhh. That makes it more interesting.
The engineer might be thinking that B wouldn't control rotation, so that is what C is for, but B would control Rotation depending on how you define it.
I love trying to peer into the mind of the drafter.
The function of this part is to rotate into position about the A axis. 2 pins extend out from the main body of the mating part into the datum B holes to lock the part into position.
I think it "could" be a valid tertiary.
However with the 2x Datum B, I think it would be best to get designs intent input.
this might be the first possible use I've seen for Calypo's new "Parallel Cylinder" feature for 2x Datum -B- ...
Good luck.
Andreas, Thank you for your sketch. Understanding a bit more of the function of this part, I'm quite sure the designer was intending to define the part as you have shown on the left sketch. But in ASME, if a feature can control a degree of freedom, it must control a degree of freedom, so the symmetry of the 2 B features controls the location along the A axis and controls rotation about the A axis. My customer is not the end customer, so communication with the designer or quality people is not something I can control.
I have to work to the standard unless my customer instructs me to do otherwise. I'm not sure my customer understood the DRF when they accepted the job. Plus, the parts are already made so no corrections can be made. I just want my customer to be armed with the correct information if they get into a discrepancy discussion with their customer.
That is the typical understanding. If you just selected features inside of Calypso inside of the Alignment/DRF, Calypso would follow the can-may-must rule, and all 6 degrees of freedom would be constrained after A & B. You would have to create an alignment that forces the Planar Rotation to be C if you didn't want B to control the rotation around the primary.
Try to imagine the function of this part is to rotate into position about the A axis. At this final position, 2 pins from the mating part will extend into the holes to lock the rotation. Datum C cannot add anything else to the function
Technically, my original post stated my interpretation of the drawing. I asked for responses that offered different interpretations, along with documentation to support the alternative interpretation. My expectation was to get interpretations based on actual standards.
