Curve Cad Help
Ok so I am NEW to curve. Took the classes last yr but have not used it till yesterday. I am trying to get a profile of the area in my screen shots that is drawn with a RED line.
When I go into wire frame it does not give me the surfaces I want but rather the surfaces that are on the outer wall area as you can see in the pics. Do I move the scan path some how to get it on the inner wall?? Hope this makes sense.
The screen shots I took are in the clipping plane mode so that Its easier to see. (I Hope)
Yes, from the Nominal Data drop-down, choose Nominal
Geometry Manipulations - Modify Nominals. To translate
in any axis click the Coordinate axis direction tab.
As long as the surface your curve is on doesn't change, say
from a wall to a cylinder, then no you'd have to section.
It looks like you don't have a wire frame available, for the inner wall that you are looking for?
If that is the case, then you need to Section your CAD model.
