[Da...] Posted February 12, 2021 Share Posted February 12, 2021 Hi all. I would like to have some project to be done and I am not sure if there is a built in option in Calypso or should I use PCM ? We have Calypso 2016, but updating to 6.6 very soon. Basically my team do not follow the rules regarding calibrations for rotary tables. I would like to have some solution of where to software checks if the table was calibrated within the last 8 hours from the actual time. If not, put a message + block possibility to run the program. My idea was that PCM could be checking the calibration files + the time and if they exist then fine if not then message(Calibration is mandatory etc.) and only cancel button. The issue is I do not really want to update each program as we have them hundreds. I would like to apply this solution to the hole Calypso so it will be OK for all programs. Any ideas ? Link to comment Share on other sites More sharing options...
[Jo...] Posted February 12, 2021 Share Posted February 12, 2021 Please sign in to view this quote. I don't have RT, but there is a setting for probe calibrations so you can assign an interval and option to notify and proceed, or simply not execute at all. Link to comment Share on other sites More sharing options...
[SH...] Posted February 13, 2021 Share Posted February 13, 2021 Please sign in to view this quote. This webinar might help you. https://youtu.be/Qy1Fhl8ok-c Link to comment Share on other sites More sharing options...
[Da...] Posted February 15, 2021 Author Share Posted February 15, 2021 Please sign in to view this quote. Cheers mate, but that is for probes only, not for RT Link to comment Share on other sites More sharing options...
[Da...] Posted February 15, 2021 Author Share Posted February 15, 2021 Please sign in to view this quote. Thank you but nothing helpful mate Link to comment Share on other sites More sharing options...
