RT Table Project
Hi all.
I would like to have some project to be done and I am not sure if there is a built in option in Calypso or should I use PCM ?
We have Calypso 2016, but updating to 6.6 very soon.
Basically my team do not follow the rules regarding calibrations for rotary tables.
I would like to have some solution of where to software checks if the table was calibrated within the last 8 hours from the actual time.
If not, put a message + block possibility to run the program. My idea was that PCM could be checking the calibration files + the time and if they exist then fine if not then message(Calibration is mandatory etc.) and only cancel button. The issue is I do not really want to update each program as we have them hundreds. I would like to apply this solution to the hole Calypso so it will be OK for all programs.
Any ideas ?
I don't have RT, but there is a setting for probe calibrations so you can assign an interval and option to notify and proceed, or simply not execute at all.
