CHARACTERISTIC'S DISAPEAR
Hello,
I recently upgraded from 5.4.16 to 6.8.08, and I've noticed quite a few little issues but the biggest thing for me is I will wright a program and it runs fine then out the blue I will loose my characteristic page completely . My features are all still there so I'll rebuild the characteristic page save it again and it might run a couple times fine and then vanish again. This doesn't happen a lot but its very frustrating never the less . Has anyone had this issue or know a way to resolve it? Thank You.
My guess is that something got fuzzy during the install and you'll probably have to re-install.
There are a lot of changes between them two versions.
I'd call the help line at 1-800-327-9735 and have them walk you thru the steps needed to correct the problem. If your CMM computer is hooked to the internet they can remote in and run some analysis.
