measurements with patterned features
I am measuring the relationship between patterned features. For example, I have a 3d curve. I need to create an intersection point on the curve, so I created a theoretical plane at a given angle. I patterned this plane to rotate 1° 11 times.
Next, I created an intersection of the 3d curve and the patterned plane, which created an array of 11 intersection points.
Next, I created a caliper distance between Intersection1(1) and Intersection1(2) and applied a tolerance for the Z direction. I repeated this 9 more times.
My question is: Is there a way to use a loop on the characteristic to select Int1(1) and Int1(2), then Int1(2) and Int1(3), and so on? WITHOUT PCM.....
I have tried all sorts of ways to get this to happen and unfortunately, I have not found anything that works. The best I have come up with is to create the first characteristic, copy and paste it, and then change from the 1 to 2, to be 3 to 2, and the next 3 to 4, etc. so you at least are only changing 1 feature within the characteristic. I wish the software was a little more intuitive in certain cases.
In the caliper distance tool, you can enter the features Int1(1,10,1) and Int1(2,11,1), and it will pattern the characteristic to give you 10 element-to-element dimensions.
At least, that's what I do for angles. Maybe it doesn't work for the caliper tool...
I seem to recall this solution from many years ago. I will give it a shot and report back.
UPDATE
Worked like a charm. Thank you Michael
So easy, so great working and so well hidden. Almost like Zeiss likes to keep that feature for themselves. Works great for all feature-to-feature stuff.
