How to Create a User-Defined Script that Accepts Arguments
Hi,
How do I create a user-defined script which can accept arguments? For example, I would like to call scriptA in scriptB. And scriptA basically just printout a simple message which I pass to it.
Example in scriptB:
gom.script.userscript.scriptA('Hello World!')
Thank you
mau
I guess it will not work by the gom.script.userscript-mechanism, which only can run a script. But it should work by the import-mechanism of python itself.
Put everything you need in a function with parameters and call this function from another script after you imported the script.
Example for scriptA:
def showMessage (message):
    print (message)
Example for scriptB:
import scriptA
scriptA.showMessage ("Hello World!")
This also works inside the folder structure inside the GOM Software in the script editor.
