Secondary Alignment
What am I doing wrong? I am measuring a pattern of 5 single plane points on the top of a part (which is conical). I created a plane using Recall Feature Points (using the 5 points) and used this plane for my Spatial rotation and Z origin. I used a circle for X/Y origin and a circle at 12 o'clock for my planar.
Next, I created a secondary alignment and used Point1 from above as my Z origin as I need to measure features relative to the Z value at that location. In the attachment below, I created a theoretical plane at Z0 in the BA. Then, I selected "Keep Position" and the secondary alignment and the plane moved up. When I converted the plane back to the BA, I had 1.085 in the Z value.
I can't seem to re-create in simulation, even with dispersion data, i.e. the theoretical plane values don't change at all.
Any thoughts?
Mystery 1.pdf
Hmm. Looks like a good ol' unintended software enhancement.
I think you are getting radius/vector comp.
I'd be interested if it behaves differently with Space Points. I'm not certain I understand the need for Plane Points, but that is more on my side of the ignorance of things.
It is a 1mm probe so 1.0845 is in the ballpark of believability. It was one of the first things that I thought of.
