[To...] Posted February 9, 2021 Share Posted February 9, 2021 What am I doing wrong? I am measuring a pattern of 5 single plane points on the top of a part (which is conical). I created a plane using Recall Feature Points (using the 5 points) and used this plane for my Spatial rotation and Z origin. I used a circle for X/Y origin and a circle at 12 o'clock for my planar. Next, I created a secondary alignment and used Point1 from above as my Z origin as I need to measure features relative to the Z value at that location. In the attachment below, I created a theoretical plane at Z0 in the BA. Then, I selected "Keep Position" and the secondary alignment and the plane moved up. When I converted the plane back to the BA, I had 1.085 in the Z value. I can't seem to re-create in simulation, even with dispersion data, i.e. the theoretical plane values don't change at all. Any thoughts?Mystery 1.pdf Link to comment Share on other sites More sharing options...
[Ri...] Posted February 9, 2021 Share Posted February 9, 2021 Any reason you aren't using Recall instead of Recall Feature Points? Are these Space Points, or Touch Points? Link to comment Share on other sites More sharing options...
[To...] Posted February 9, 2021 Author Share Posted February 9, 2021 Please sign in to view this quote. Because of this.... Plane Points because the surface is conicalScreenshot 2021-02-09 123155.png Link to comment Share on other sites More sharing options...
[Ri...] Posted February 9, 2021 Share Posted February 9, 2021 Hmm. Looks like a good ol' unintended software enhancement. I think you are getting radius/vector comp. I'd be interested if it behaves differently with Space Points. I'm not certain I understand the need for Plane Points, but that is more on my side of the ignorance of things. Link to comment Share on other sites More sharing options...
[To...] Posted February 9, 2021 Author Share Posted February 9, 2021 Please sign in to view this quote. It is a 1mm probe so 1.0845 is in the ballpark of believability. It was one of the first things that I thought of. Link to comment Share on other sites More sharing options...
