Keyboard setting
My mouse selection setting has changed. I don't know how. I made some setting changes in Calypso but not sure If it is a Windows or Calypso setting.
If I left click on anything, Characteristic or Feature, it stays selected as if I had Control key on. It won't let me Shift to select all, and I have to deselect any highlighted once they are selected.
  • 5 months later...
I'm having the same issue. multiple select will not work using the ctrl or shift keys. I have to click on selected items to deselect. HELP! This only happens in Calypso. In other file folders, it operates normally.
Not sure if its related but my keyboard seems to act a bit funky as well. for example my delete key doesn't delete characters/features but works normally outside of calypso. I do have the same Shift key issue...Who knows, maybe when they release a patch it will fix it, until then, CTL + Up/Down should work.
