[Jo...] Posted August 14, 2020 Share Posted August 14, 2020 My mouse selection setting has changed. I don't know how. I made some setting changes in Calypso but not sure If it is a Windows or Calypso setting. If I left click on anything, Characteristic or Feature, it stays selected as if I had Control key on. It won't let me Shift to select all, and I have to deselect any highlighted once they are selected. Link to comment Share on other sites More sharing options...
[Ch...] Posted August 14, 2020 Share Posted August 14, 2020 I don't know much about it, but it sounds like you have 'sticky keys' activated. Link to comment Share on other sites More sharing options...
[Jo...] Posted August 14, 2020 Author Share Posted August 14, 2020 Please sign in to view this quote. Doesn't appear to be. It is off. Link to comment Share on other sites More sharing options...
[Jo...] Posted August 14, 2020 Author Share Posted August 14, 2020 It was a self created problem.. View/configuration/touch settings/ "hold down Ctrl key when making multiple selection in list" Link to comment Share on other sites More sharing options...
[sh...] Posted February 4, 2021 Share Posted February 4, 2021 I'm having the same issue. multiple select will not work using the ctrl or shift keys. I have to click on selected items to deselect. HELP! This only happens in Calypso. In other file folders, it operates normally. Link to comment Share on other sites More sharing options...
[Me...] Posted February 8, 2021 Share Posted February 8, 2021 Not sure if its related but my keyboard seems to act a bit funky as well. for example my delete key doesn't delete characters/features but works normally outside of calypso. I do have the same Shift key issue...Who knows, maybe when they release a patch it will fix it, until then, CTL + Up/Down should work. Link to comment Share on other sites More sharing options...
