[Ja...] Posted February 4, 2021 Share Posted February 4, 2021 I have done this before, but I can't remember how I did it. I need to create a circle Ø.186 to get my .749 dimension. I do not have a solid model. I have the two planes that form the V, but I can't remember how to align the circle to them. Any help would be appreciated. Link to comment Share on other sites More sharing options...
[Ja...] Posted February 4, 2021 Share Posted February 4, 2021 If you create two lines from the planes then you can use tangent circle. Link to comment Share on other sites More sharing options...
[Ja...] Posted February 4, 2021 Author Share Posted February 4, 2021 I was able to create lines using an intersection and each plane, so that worked. I can't figure out how to create a line just using a plane. Is there an easy way to do that? Thanks Link to comment Share on other sites More sharing options...
[Jo...] Posted February 4, 2021 Share Posted February 4, 2021 offset each plane the radius distance, and they will intersect at the circle centerline. You can place a theo plane at each end and get intersection in both places. You can then make a theo circle with formula using those coordinates, or result element and do the math. Link to comment Share on other sites More sharing options...
[Ja...] Posted February 4, 2021 Share Posted February 4, 2021 Please sign in to view this quote. That's what I would do is intersect the planes with the plane that's perpendicular to it to get lines. You could do it on both ends. I think offsetting the planes like John mentioned works too. Link to comment Share on other sites More sharing options...
