[Ia...] Posted February 1, 2021 Share Posted February 1, 2021 I am trying to offset my base alignment 0.005" in 'Z' from my actual probed 'Z' plane in order to account for my other measurements including curve being offset 0.005". I have tried adding the offset in my base alignment under 'special', but am getting no change in my results. Is there something else that I should be doing? Link to comment Share on other sites More sharing options...
[Cl...] Posted February 1, 2021 Share Posted February 1, 2021 Just use a secondary alignment offset by .005, and reference the other measurements to that alignment. Link to comment Share on other sites More sharing options...
[Jo...] Posted February 1, 2021 Share Posted February 1, 2021 Depending on what you are trying to accomplish, changing the nominal value of the plane could work as well. An example of this would be if your plane had stock on it for machining. You could change the nominal from zero to a positive number to account for stock. If you are reporting profile or position, the nominals are tied to model features, relative to each other, so alignment wouldn't "correct" that. Link to comment Share on other sites More sharing options...
[Jo...] Posted February 1, 2021 Share Posted February 1, 2021 Please sign in to view this quote. FYI , you can pre assign an alignment to new features, or use the paintbrush tool afterwards when utilizing Clarke's suggestion. Link to comment Share on other sites More sharing options...
[Ia...] Posted February 3, 2021 Author Share Posted February 3, 2021 Yes, so my datum plane had 0.005" removed from it by mistake. However I have many other existing features which were referenced from that datum. So now it is showing that those features measure +0.005". I was hoping to offset the plane so that I know if the other features are good with respect to the ghost datum now. Link to comment Share on other sites More sharing options...
[Jo...] Posted February 3, 2021 Share Posted February 3, 2021 Please sign in to view this quote. Easy, Just construct a plane with offset from your datum, and make it an alternate Datum. You can report both. Link to comment Share on other sites More sharing options...
