[Ad...] Posted September 8, 2022 Share Posted September 8, 2022 Is there a way to measure the radius of curvature along a section curve? I don't need the radius of curvature perpendicular to the curve, but rather along it. It sounds like the "character values" fitting element may work, but it doesn't seem to be an option on section curves. Link to comment https://qualityforum.zeiss.com/topic/1363-radius-of-curvature-on-section-curve/ Share on other sites More sharing options...
[Be...] Posted September 9, 2022 Share Posted September 9, 2022 Hi, what about: Select the curve in the explorer Open I-Inspect Apply 'Curve Curvature' Afterwards you can check the create dimension curve e.g. on curvature or radius Hope this helps?! Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/1363-radius-of-curvature-on-section-curve/#findComment-4499 Share on other sites More sharing options...
[Ad...] Posted September 12, 2022 Author Share Posted September 12, 2022 I think adding a radius check on the curve curvature fitting method worked. Thanks! Link to comment https://qualityforum.zeiss.com/topic/1363-radius-of-curvature-on-section-curve/#findComment-4521 Share on other sites More sharing options...
