measure bore Ø by probe shank
K,
there are different ways:
1. you measure the ball probe on your referenc sphere and than the shaft from your probe. The difference you must calculate in the result.
2. you calibrate the shaft as e new cylinder probe.
Hope that helps!? 🙄
