[Ad...] Posted September 8, 2022 Share Posted September 8, 2022 I have two actual curves I would like to compare to each other, but I can't find a way to do it. It seems that the only way it can be done is by having a nominal curve and an actual curve linked to each other via a measuring principle. Is there a work around to make this work? Link to comment Share on other sites More sharing options...
[Be...] Posted September 9, 2022 Share Posted September 9, 2022 Hi, have you tried: Construct -> Distance -> Continuous Curve Distance and to apply a distance check on it? Regards, Bernd Link to comment Share on other sites More sharing options...
[Ad...] Posted September 9, 2022 Author Share Posted September 9, 2022 Thanks for the tip! It works! I never thought to look in the Distance submenu. Link to comment Share on other sites More sharing options...
