[Za...] Posted January 27, 2021 Share Posted January 27, 2021 When measuring with star probe, do I have to change stylus manually everytime for each star direction? Is there any option to do that thing automaticly? Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/ Share on other sites More sharing options...
[Cl...] Posted January 27, 2021 Share Posted January 27, 2021 Assign stylus per feature using the measurement plan editor. Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70062 Share on other sites More sharing options...
[To...] Posted January 27, 2021 Share Posted January 27, 2021 When probing features on part, pre-select which stylus to use and the feature will retain that selection. When programming from a model, it is a good practice to do the same thing but a lot of people forget, me included. Like Clarke said, you can use the Features Setting Editor to edit the stylus assignments. You should also review your Clearance Plane assignments. Nothing worse than probing a feature with the wrong stylus and approaching the feature from the wrong side of the part. Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70064 Share on other sites More sharing options...
[Ün...] Posted January 27, 2021 Share Posted January 27, 2021 Merhaba Zafer, Program oluştururken yıldız problarda hangi uç ile ölçüm yapacak isen joystikten veya yazılımdan ilgili probu seçmen gerekir. Calypso hangi uç ile dokunacağını bilemez. Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70066 Share on other sites More sharing options...
[Jo...] Posted January 27, 2021 Share Posted January 27, 2021 Please sign in to view this quote. I don't know how many people know or use it.. Resources>Stylus System>Automatic Stylus Assignment Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70068 Share on other sites More sharing options...
[Cl...] Posted January 27, 2021 Share Posted January 27, 2021 Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70070 Share on other sites More sharing options...
[To...] Posted January 27, 2021 Share Posted January 27, 2021 Please sign in to view this quote. I have used this quite successfully on many star probes and RDS styli. However, it doesn't work on RDS-CAA styli. Link to comment https://qualityforum.zeiss.com/topic/13654-star-probe-stylus-change/#findComment-70072 Share on other sites More sharing options...
