Circumferential Groove Measurement
Hi.
I've been asked to modify our methodology of measurement of circumferential grooves to suit our customers methodology who uses Mitutoyo software.
Here is an example of one of their programs methods, but in this case the Gauge Height is 14,8mm.
I've tried a couple of ideas, but the PCM fails with reciprocal dependencies.
Any ideas of how I can achieve this? Any pointers would be greatly appreciated. Below is where i've got to so far. 2161_d01007b81a93239b09c0516d689c922e.jpg
Thanks in advance.
https://qualityforum.zeiss.com/topic/13674-circumferential-groove-measurement/
notice that using line features you are intersecting with the LSQ line (or the method selected to generate the line), for more accurate result I would use a curve instead..
also you don’t need a loop to generate the intersection with the gauge value, you can generate a theoretical cylinder with this value an intersect it with the two sections..
Edit: my mistake this method is not going to center correctly the gauge diameter…
I agree that the curve might produce a more accurate measurement, however the method you've described doesn't match the spec required from the customer.
This is where I've got to so far with experimenting, it kind of seems to work, however the GAUGE variable doesn't update and it doesn't stop when reached it's specified dimension. 2161_9480024f2b2b89bd93c39e356dbcc42b.jpg
Loops in calypso are very slow is better to have bigger steps, this works OK:
GAUGE=10.9
CIR_R= 2  // Nominal Value
Step=0.2
Diff=999
repeat
CIR_R = CIR_R+Step
measure("Theo 3d Line1")
measure("Theo Int Upper")
measure("Theo Int Lower")
if abs(GAUGE - (getActual("Theo Int Upper").z- getActual("Theo Int Lower").z)) < Diff then
Diff=abs(GAUGE - (getActual("Theo Int Upper").z- getActual("Theo Int Lower").z))
else
CIR_R =CIR_R -Step
Step=-Step/2
endif
until abs(Step) <= 0.0001
  • Awesome! 1
I've just tried that method and it seems to have overshot the target again.
Plus I have a simple distance between the intersections in characteristics which doesn't update until you manually interrogate the features. This changes due to the variables shifting the 3d line, but doesn't show at the end of the run.
Does anyone know why?
Anyone with any other solutions i could try?
We had already developed a method to measure this feature prior to this.
  • Create a line on each pressure face
  • Create a symmetry of these pressure faces
  • Recall One Feature of the symmetry as a 2d Line
  • Offset this 2d Line by half of the Gauge Height (in this case 10.9/2) in the Z axis. One going +Z and one -Z
  • Intersect these offset 2d Lines to the corresponding measured 2d Line Pressure Faces
  • Repeat this process several times around the circumference
  • Recall this intersections as a circle to create the required diameter
  • 4 years later...
