[SH...] Posted January 21, 2021 Share Posted January 21, 2021 When my angel unit is degrees minutes and seconds , I can't edit the strategy range angles. When I convert it to degrees it works... 😠IMG20210121170841.jpg Link to comment Share on other sites More sharing options...
[To...] Posted January 21, 2021 Share Posted January 21, 2021 Please sign in to view this quote. From your signature block, it appears you probably could use a service pack. Link to comment Share on other sites More sharing options...
[SH...] Posted January 21, 2021 Author Share Posted January 21, 2021 Calypso 6.6003 patch version.. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 21, 2021 Share Posted January 21, 2021 Please sign in to view this quote. Go to https://portal.zeiss.com/ - Download Center - Zeiss Calypso - Select 2018 (6.6) on the right hand side. Download the latest Service Pack Link to comment Share on other sites More sharing options...
[Me...] Posted January 21, 2021 Share Posted January 21, 2021 Try typing it in as decimal degrees, if it's the same problem I've had with DMS anyways. Link to comment Share on other sites More sharing options...
[SH...] Posted January 21, 2021 Author Share Posted January 21, 2021 Please sign in to view this quote. Ok, I will try this. Link to comment Share on other sites More sharing options...
