[Ro...] Posted January 18, 2021 Share Posted January 18, 2021 Hi all, We have a machine that needs to be upgraded from Windows 7 to Windows 10. Any issues running 2014 (5.8) on a Windows 10 machine? Thanks for any information you may have. Robert Link to comment Share on other sites More sharing options...
[Ow...] Posted January 19, 2021 Share Posted January 19, 2021 Probably best to call the support line 1-800-327-9735 and get a direct answer to this question. You shouldn't have to have an active SMA to get an answer on compatibility. However, (I could be wrong) get ready to open your pocket book because I _"think" _ widows 10 became supported in version 6.2??? Calypso 6.4 (2017) was the latest version to be guaranteed compatible with widows 7 but, I believe I did run up to 6.6 on a windows 7 system and changed to 6.8 when we upgraded to a windows 10 computer.. Link to comment Share on other sites More sharing options...
[Th...] Posted January 19, 2021 Share Posted January 19, 2021 The release info PDF for 5.8 doesn't list Windows 10 as a compatible OS. I would expect it to *probably* function fine, but it's something I would want to test before replacing a production workstation. At any rate, Zeiss would absolutely not provide any support for such a configuration. If you have an IT department demanding its replacement and no budget for a new Calypso license, you might try convincing them to restrict its network access or just airgap it entirely. Please sign in to view this quote. 6.6 is actually the last major release to be officially supported on 7. Link to comment Share on other sites More sharing options...
[Ro...] Posted January 19, 2021 Author Share Posted January 19, 2021 Thank you Owen/Thomas. I appreciate the information. 🙂 Link to comment Share on other sites More sharing options...
