[Za...] Posted January 6, 2021 Share Posted January 6, 2021 I have some true position callouts that are giving me a result of 0.000000" instead of something greater than zero. I've seen this in the past and I just want to know why it does this? Is it because I'm taking the true position of a circle instead of a cylinder? Thank you as always for the help! Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/ Share on other sites More sharing options...
[Er...] Posted January 6, 2021 Share Posted January 6, 2021 I could be mistaken but it looks like checking a circle to a Datum A only would be reporting the perpendicularity, which on a circle would be zero. It should be a cylinder which would then report the deviation of the Cylindrical hole to Datum A. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70360 Share on other sites More sharing options...
[Za...] Posted January 6, 2021 Author Share Posted January 6, 2021 Please sign in to view this quote. I appreciate the help! Thanks Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70362 Share on other sites More sharing options...
[To...] Posted January 6, 2021 Share Posted January 6, 2021 Using datum A only will allow the X and Y to translate to its' nominal position, effectively reporting zero TP. If you measured a cylinder, then the axis deviation or perpendicularity would calculated, like previously mentioned. Are there a group of holes sharing the same position? If so, you need to change the Position to a Best Fit Bore pattern (icon at top below the position label),,, Then select all of the circles. In the same window, you will leave Rotation and Translation best fit options checked. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70364 Share on other sites More sharing options...
[Za...] Posted January 6, 2021 Author Share Posted January 6, 2021 Please sign in to view this quote. My issue was taking the TP of circles to just the one datum (The plane the features are on). I knew I've seen this before and I thought that I fixed them by making them cylinders, but I had never heard the explanation. It definitely makes sense now. Thanks again for the help (I'm a repeat offender on asking questions in here 🤣 ) Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70366 Share on other sites More sharing options...
[Ra...] Posted January 6, 2021 Share Posted January 6, 2021 Ya do what Tom Oakes said. If it's a perpendicularity callout, use the perp function in calypso and use a cylinder. If it's a position to a single datum like that, it needs to be a bestfit of a hole pattern (6x on the callout for example) evaluated at once. If it's a position to a single datum and only a single hole, it's an invalid callout and you need to ask the engineer what they wanted. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70368 Share on other sites More sharing options...
[SH...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. I think he misunderstood the drawing or something wrong in the drawing. If it is a one datum plane and cylinder , then why true position. If things are going this way,we can see the elimination of perpendicularly and parallelism in upcoming ASME standard. Bore pattern can be called with respect to a plane?. I think it should be with the centre bore. Can we tick the check box with out knowing FCF call out? He might not have MMB call out. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70370 Share on other sites More sharing options...
[Ja...] Posted January 7, 2021 Share Posted January 7, 2021 What Tom said is correct. I occasionally see bores held to one datum (their parent surface) and every time I've asked what the primary concern was with said bore, I was always told "tilt." So, yeah, most likely what the engineer wants to see is axial tilt to the parent surface, or (drum roll) perpendicularity! I usually just drop in a perpendicularity characteristic, apply my feature and datum, click on the "comment" button and enter something like "True Position as Perpendicularity." Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70372 Share on other sites More sharing options...
[To...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. We really don't have all of the information. He could be referring to a lower tier of a composite true position. And, if it is the lower tier of a composite position, then a group of holes called to datum A are still allowed to translate and rotate regardless of MMB, which would not apply in this case. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70374 Share on other sites More sharing options...
[Ch...] Posted January 7, 2021 Share Posted January 7, 2021 Position to one planer datum is totally legit in 14.5. Meant to control orientation and location. I wish more designers would use this strategy. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70376 Share on other sites More sharing options...
[Za...] Posted January 7, 2021 Author Share Posted January 7, 2021 This is the callout if anybody is interested for discussion purposes 😃 Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70378 Share on other sites More sharing options...
[Ch...] Posted January 7, 2021 Share Posted January 7, 2021 bonus to anyone who knows what Circle S means without google. extra credit for knowing when it was obsoleted. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70380 Share on other sites More sharing options...
[Da...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. Too late I already Googled it! But, I won't tell. 😃 Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70382 Share on other sites More sharing options...
[Mi...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. What does "knowing the name, but not understanding the concept" get me? Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70384 Share on other sites More sharing options...
[SH...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. I know you are kidding eventhough, I added the photo. It is default condition....IMG_20210107_200233.jpg Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70386 Share on other sites More sharing options...
[Ri...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. Then the holes must be evaluated together in a Best-Fit. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70388 Share on other sites More sharing options...
[SH...] Posted January 7, 2021 Share Posted January 7, 2021 Only one plane, how location of best fit work?? Really interesting.... Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70390 Share on other sites More sharing options...
[Ri...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. It is a fit to themselves. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70392 Share on other sites More sharing options...
[Er...] Posted January 7, 2021 Share Posted January 7, 2021 Tom, as much as i agree with you that it is a fit to themselves, there is nothing locating the two holes to anything else. I still think the callout is flawed and the holes are designed to be located from some other feature as well. Afterall, the print shows a 1.428 basic from the center hole to the hole pattern. It doesn't make sense that these 2 holes don't have an additional position or location in X and Y. I would definitely ask for additional information as to what is needed. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70394 Share on other sites More sharing options...
[Ch...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. What Tom stated is entirely accurate to how the print is written; However, Eric may have a point as well. The Circle S indicates that this is probably a pre-1994 print. From my understanding, using this position to one datum design strategy was not as common back then. Maybe we have a very forward thinking pre-1994 designer at work here, but I would be a little suspicious of design intent in this particular situation. Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70396 Share on other sites More sharing options...
[To...] Posted January 7, 2021 Share Posted January 7, 2021 Please sign in to view this quote. Spot on Eric. I was trying to answer the question with information on hand. Didn't even consider that we might be talking about an ancient drawing from my youthful days...LOL Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70398 Share on other sites More sharing options...
[Er...] Posted January 15, 2021 Share Posted January 15, 2021 Unfortunately, all too often I deal with prints like this. LOL Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70400 Share on other sites More sharing options...
[An...] Posted January 16, 2021 Share Posted January 16, 2021 Please sign in to view this quote. Best-Fit means aligning the 2 symmetry points and zeroing the symmetry point. See attached.Contribution_16_01_2021_1.pdf Link to comment https://qualityforum.zeiss.com/topic/13694-true-position-not-registering-a-result/#findComment-70402 Share on other sites More sharing options...
