[Mi...] Posted April 15, 2019 Share Posted April 15, 2019 Hello everybody, Is there a way to save a Calypso test plan in a previous version? Calypso Version 2018 save down to 2017. Best regards Mikel Link to comment https://qualityforum.zeiss.com/topic/13696-save-a-calypso-test-plan-in-a-previous-version/ Share on other sites More sharing options...
[Kl...] Posted April 15, 2019 Share Posted April 15, 2019 Hallo Mikel ist nicht immer notwendig. Im Prüfplanverzeichnis befindet sich eine Datei "Version". Diese mit einem Editor öffnen und den Eintrag, in diesem Fall von 6.6.xxxx auf 6.4.xxxx ändern. Der Prüfplan sollte dann in der älteren Version geöffnet werden können, falls keine "Schweinereien" enthalten sind. Ggf. sind Funktionen in 6.4 anzupassen, falls diese erst ab 6.6 vorhanden sind. Viel Erfolg Gruß Klaus-Dieter Link to comment https://qualityforum.zeiss.com/topic/13696-save-a-calypso-test-plan-in-a-previous-version/#findComment-70406 Share on other sites More sharing options...
[Mi...] Posted April 15, 2019 Author Share Posted April 15, 2019 Hallo Klaus-Dieter, das hört sich doch gut an. Teste ich so einmal durch. Danke! Gruß Mikel Link to comment https://qualityforum.zeiss.com/topic/13696-save-a-calypso-test-plan-in-a-previous-version/#findComment-70408 Share on other sites More sharing options...
[Gu...] Posted January 15, 2021 Share Posted January 15, 2021 Hi there, This method doesn't work between 6.8 to 6.6. Any alternative? I have 18 machines measuring production 24h/7 and i cannot stop the machines to make the update every time i want. Thanks Guilherme Link to comment https://qualityforum.zeiss.com/topic/13696-save-a-calypso-test-plan-in-a-previous-version/#findComment-70410 Share on other sites More sharing options...
[Mi...] Posted January 15, 2021 Share Posted January 15, 2021 I just had to do 6.8 to 6.6. I got it to work, but it's a process. Something you only do once. Copy your program file from the 6.8 machine to the 6.6 machine. Create a new file with the exact same name in a different directory ( Calypso will take the program name from this) Copy the "inspection" file from the 6.8 program folder to the new one you just created. Now open that inspection file in 6.6 and you should be good to resave it. As long as you're not using anything from 6.8 that doesn't exist in 6.6 that is. For whatever reason this method did not work on all of our programs, but hopefully it gets you started. My offline seat is 6.0 and it allows me to open and edit up to 6.6, but we have one machine on 6.8. What we do now is we've blocked saving on the 6.8 machine and ONLY edit it via the offline seat, then there is no issues. 1 Link to comment https://qualityforum.zeiss.com/topic/13696-save-a-calypso-test-plan-in-a-previous-version/#findComment-70412 Share on other sites More sharing options...
