Save a Calypso test plan in a previous version
Hello everybody,
Is there a way to save a Calypso test plan in a previous version?
Calypso Version 2018 save down to 2017.
Best regards
Mikel
Hallo Mikel
ist nicht immer notwendig.
Im Prüfplanverzeichnis befindet sich eine Datei "Version". Diese mit einem Editor öffnen und den Eintrag, in diesem Fall von
6.6.xxxx auf
6.4.xxxx
ändern.
Der Prüfplan sollte dann in der älteren Version geöffnet werden können, falls keine "Schweinereien" enthalten sind.
Ggf. sind Funktionen in 6.4 anzupassen, falls diese erst ab 6.6 vorhanden sind.
Viel Erfolg
Gruß
Klaus-Dieter
  • 1 year later...
Hi there,
This method doesn't work between 6.8 to 6.6.
Any alternative?
I have 18 machines measuring production 24h/7 and i cannot stop the machines to make the update every time i want.
Thanks
Guilherme
I just had to do 6.8 to 6.6. I got it to work, but it's a process. Something you only do once.
Copy your program file from the 6.8 machine to the 6.6 machine.
Create a new file with the exact same name in a different directory ( Calypso will take the program name from this)
Copy the "inspection" file from the 6.8 program folder to the new one you just created.
Now open that inspection file in 6.6 and you should be good to resave it. As long as you're not using anything from 6.8 that doesn't exist in 6.6 that is. For whatever reason this method did not work on all of our programs, but hopefully it gets you started.
My offline seat is 6.0 and it allows me to open and edit up to 6.6, but we have one machine on 6.8. What we do now is we've blocked saving on the 6.8 machine and ONLY edit it via the offline seat, then there is no issues.
  • Thank you! 1
