Sphere on Torus
I need to measure the diameter of an intersection of a sphere on the surface of a torus. Not sure what I mean? Imagine a dimple on a golf ball but the ball is really a portion of a torus. Any ideas?
I might have done something like this a long time ago. But I had a torus cutout on the spehere.
What I ended up doing was measuring curves that "fell" over the intersection edge. Placed a CS in the center of the torus thing.
Collect the highest points of the curve. And recall to an ellipse. (Maybe I did some projection? Cant remember.) That was the most repetable of everything I tried. 114_e64f11d7067daecda413d39cf83b41ce.png
(Thin lines are curves)
But you might be trying to explain something else?
The shape you're describing doesn't have a diameter, does it? Isn't it saddle-shaped, like the edge of a pringle?
Anyway, the only thing I can think of to do is:
- Measure the sphere (as a sphere)
- Measure the torus (as a torus)
- Measure a number of arcs across the region of interest. For the ones in the dimple, constrain them to the radius or position of the sphere (I'm not sure which would work best). Do the same for the torus immediately around the dimple.
- Create intersections from the arcs, recall into a circle, and report the diameter.
This kinda fudges it, though, since the points won't actually be coplanar, unless I'm picturing it wrong.
Something like a ball of bearing on cycle tyre tube?? I have not worked with both sphere and torus simultaneously. Direct intersection is not possible??
Technically, you are correct but the torus is so close to being a sphere, the customer has specified a diameter and are currently checking it as a diameter on a MicroVu. Thank you for the ideas. I'll give them a try.
No, intersections don't work with a torus. I have a phrase that I use every time someone mentions they are working a torus and it goes like this. "A torus doesn't play well with others."
I'd create several curves through the sphere, scan those and recall them
into a sphere feature, and because its such a small segment you'd have
to constrain location, then intersect with torus and shell for diameter.
Two options:
- Vision
- Measure curves that are 90 apart from one another (like in the attached picture), and create the intersections.
There could be a third where if you can actually measure it as a sphere, and just use a theoretical plane (it would need to be tangent to the torus) to create the intersection.
2d curve, recall the points into a line and a circle. Pretty sure the construction should be curve - line- circle.
You will have to use two circles, not sure if that will work. If the torus diameter is big enough, you could use
a short line. I've only used the line an circle method.
For a minute, I thought this was a reply from Andreas 😃 Please elaborate on the 2 circles. I think I understand the curve.
He's talking about the three inputs to the kink point. The first should be a curve that goes over the kink, the second should be an arc recalled from the curve just before the kink, and the third should be an arc recalled from just after the kink.
I can't vouch for it, though, as I've never tried it myself. And I'm not sure if the order of the last two features matters.
Nevermind. You cannot select which side of the intersection you want. Intersection is the only way - it may not work because Calypso hates trying to intersect 2d features.
