Sphere on Torus
I might have done something like this a long time ago. But I had a torus cutout on the spehere.
What I ended up doing was measuring curves that "fell" over the intersection edge. Placed a CS in the center of the torus thing.
Collect the highest points of the curve. And recall to an ellipse. (Maybe I did some projection? Cant remember.) That was the most repetable of everything I tried. 114_e64f11d7067daecda413d39cf83b41ce.png
(Thin lines are curves)
But you might be trying to explain something else?
https://qualityforum.zeiss.com/topic/13700-sphere-on-torus/#findComment-70422
The shape you're describing doesn't have a diameter, does it? Isn't it saddle-shaped, like the edge of a pringle?
Anyway, the only thing I can think of to do is:
- Measure the sphere (as a sphere)
- Measure the torus (as a torus)
- Measure a number of arcs across the region of interest. For the ones in the dimple, constrain them to the radius or position of the sphere (I'm not sure which would work best). Do the same for the torus immediately around the dimple.
- Create intersections from the arcs, recall into a circle, and report the diameter.
This kinda fudges it, though, since the points won't actually be coplanar, unless I'm picturing it wrong.
https://qualityforum.zeiss.com/topic/13700-sphere-on-torus/#findComment-70424
Two options:
- Vision
- Measure curves that are 90 apart from one another (like in the attached picture), and create the intersections.
There could be a third where if you can actually measure it as a sphere, and just use a theoretical plane (it would need to be tangent to the torus) to create the intersection.
https://qualityforum.zeiss.com/topic/13700-sphere-on-torus/#findComment-70450
2d curve, recall the points into a line and a circle. Pretty sure the construction should be curve - line- circle.
You will have to use two circles, not sure if that will work. If the torus diameter is big enough, you could use
a short line. I've only used the line an circle method.
https://qualityforum.zeiss.com/topic/13700-sphere-on-torus/#findComment-121258
He's talking about the three inputs to the kink point. The first should be a curve that goes over the kink, the second should be an arc recalled from the curve just before the kink, and the third should be an arc recalled from just after the kink.
I can't vouch for it, though, as I've never tried it myself. And I'm not sure if the order of the last two features matters.
https://qualityforum.zeiss.com/topic/13700-sphere-on-torus/#findComment-70460
