[Vo...] Posted September 12, 2022 Share Posted September 12, 2022 Hallo zusammen, im "alten" Forum existierte ein script, um alle Bilder eines Reports in einen frei wählbaren Ordner zu exportieren. Hat das noch jemand zur Hand? Es ist sehr zeitaufwendig, jedes Bild einzeln zu exportieren. Vielen Dank im Voraus. Link to comment Share on other sites More sharing options...
[5b...] Posted September 19, 2022 Share Posted September 19, 2022 This script will export all the images in your report pages to a directory you select # -*- coding: utf-8 -*- import os import gom dialog=gom.script.sys.execute_user_defined_dialog (content='<dialog>' \ '<title>Export to folder:</title>' \ '<control id="OkCancel"/>' \ '<size height="100" width="200"/>' \ '<content columns="1" rows="1">' \ '<widget type="input::file" row="0" rowspan="1" column="0" columnspan="1">' \ '<name>folder</name>' \ '<type>directory</type>' \ '<title>choose folder:</title>' \ '<default></default>' \ '<limited>false</limited>' \ '<file_types/>' \ '<file_types_default></file_types_default>' \ '</widget>' \ '</content>' \ '</dialog>') export_folder = dialog.folder.replace('/', os.sep) for report in sorted(gom.app.project.reports): for element in report.pages[0].elements: if element.type == 'figure_snapshot_frame': i = 1 while True: if os.path.exists(os.path.join(export_folder, '{} {}.png'.format(report.name, i))): i += 1 else: break gom.script.report.export_report_image_as_png(images=element, file=os.path.join(export_folder, '{} {}.png'.format(report.name, i)), use_original_size=True, disable_transparency=True) Link to comment Share on other sites More sharing options...
[Vo...] Posted September 20, 2022 Author Share Posted September 20, 2022 Vielen Dank. Funktioniert wunderbar! Eine Menge Arbeit gespart👍 Link to comment Share on other sites More sharing options...
