Output data from Calypso to XML
Has anyone done, or have knowledge of how this is done.
We will be using a customer portal to enter variable CMM
data and it needs to be in the XML format. I do have PCM.
After extensive research i found that there is a TXT to XML converter, so maybe you export what they need to TXT, and manually convert them before submission??
Seems like a job for an intern.
The XML standard doesn't define a ready-to-go file format, but is more or less just a basic definition of a tagged hierarchical list of entries. What these tags are or what they mean is up to the implementor. So if you want to convert a text file to XML by yourself, you need to know which tags are used in the file and if/when they are valid.
