[Cl...] Posted January 12, 2021 Share Posted January 12, 2021 Has anyone done, or have knowledge of how this is done. We will be using a customer portal to enter variable CMM data and it needs to be in the XML format. I do have PCM. Link to comment https://qualityforum.zeiss.com/topic/13718-output-data-from-calypso-to-xml/ Share on other sites More sharing options...
[Ro...] Posted January 13, 2021 Share Posted January 13, 2021 After extensive research i found that there is a TXT to XML converter, so maybe you export what they need to TXT, and manually convert them before submission?? Seems like a job for an intern. Link to comment https://qualityforum.zeiss.com/topic/13718-output-data-from-calypso-to-xml/#findComment-70592 Share on other sites More sharing options...
[No...] Posted January 14, 2021 Share Posted January 14, 2021 The XML standard doesn't define a ready-to-go file format, but is more or less just a basic definition of a tagged hierarchical list of entries. What these tags are or what they mean is up to the implementor. So if you want to convert a text file to XML by yourself, you need to know which tags are used in the file and if/when they are valid. Link to comment https://qualityforum.zeiss.com/topic/13718-output-data-from-calypso-to-xml/#findComment-70594 Share on other sites More sharing options...
