[Li...] Posted January 13, 2021 Share Posted January 13, 2021 Is it possible and reliable to use a disk probe on a Contura with RDS-CAA probe head? Link to comment Share on other sites More sharing options...
[SH...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. First point , your width is too small. I have a disc probe , it's width is 3mm. It will be difficult for that size. Second point, you can't use disc probe in RDS. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 13, 2021 Share Posted January 13, 2021 You have an RDS, build an L probe, and measure it in 4 positions. Link to comment Share on other sites More sharing options...
[SH...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. His width is too small, does it is possible to check in CMM? Link to comment Share on other sites More sharing options...
[Jo...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. You can use a 1.5mm probe. I would use a symmetry point (from each side of groove) in a formula to locate circle in the center of groove width. It is also possible to use a larger probe and self center strategy on the groove to locate center. Link to comment Share on other sites More sharing options...
[SH...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. Ohh it is my conversion mistake, we work with mm .. Thanks for your points.. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 13, 2021 Share Posted January 13, 2021 My goal is to convert everyone to not use Disc Probes at some point in my career. Lol. Link to comment Share on other sites More sharing options...
[SH...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. What about cylindrical probe?. I got offer letter from a new company. They asked me about how to calibrate cylindrical probe. They don't know how to calibrate it!!!. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 13, 2021 Share Posted January 13, 2021 Cylinder probes are great for sheet metal, or trying to capture thin edges. The biggest problem is that you have no guarantee that the cylinder probe is perpendicular to the surface, and so when you are measuring a feature you don't know if you are hitting on the area where it is qualified to. If you have huge tolerances, it doesn't matter though. Link to comment Share on other sites More sharing options...
[Me...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. I'm curious to know why?? Link to comment Share on other sites More sharing options...
[Ri...] Posted January 13, 2021 Share Posted January 13, 2021 Please sign in to view this quote. IMO they are useless. It is better to create a t or star probe which will give you the option to measure form, size, and location of a groove. You are extremely limited to what you can do with a disc probe, and the setup is a pain in the butt. Not worth it. Once again, this is my own opinion. I've measured a wide array of parts from various industries, and I've still yet to encounter an application where I just had to have a disc probe. I'm sure there is one out there, but I've yet to see it. Link to comment Share on other sites More sharing options...
[Ow...] Posted January 13, 2021 Share Posted January 13, 2021 I use disk's more than I'd like to but, sometimes it's the most fea$ible. The system pictured took a lot of work (trial and error) weighing, measuring and compensating with gage correction qualification to get the results/variation I wanted but, I got it within 0.002mm of what I'd get with a shorter dynamic tensor qualified probe. Had to slow it way down and up the measuring force (mN) to 500 to subdue noise/chatter. A hollow half Hemisphere would have been better but the cost of a special made one was a prohibitive NO. Link to comment Share on other sites More sharing options...
