Older versions of GOM Inspect?
I have always used the GOM Inspect 2016 and my company issued me a new computer and now I no longer have it.  I went to the myGom website to download it today and I cannot find any previous versions of GOM Inspect. I was once able to view and download any of the older versions of GOM from this site.  Can I still download the GOM Inspect 2016 free version, and if so, could you tell me where?
Thanks
Hello
Hope you are doing well and good.
Gom doesn't provide 2016 setup file access anymore for GOM Inspect .
On the official website the oldest version whose setup access is available is GOM Inspect 2019 .
Kindly follow this steps to download the 2019 setup ( If interested ) - Suggested Method
hope this work well and sort your issues .
Good luck
Hello Brian,
we provide the installer of the older software.
The easiest way is to go to my.gom.com and go to the software area.
on the left side you can search for a specific version.
Greetings, Ivan
  • 2 years later...
  • 2 months later...
Where is now the Library ...?
Hi Ali,
library.gom.com now redirects to qualitylibrary.zeiss.com, where you can find older versions
  • 1 month later...
Hello Robert,
now this link redirects to a celum space...and hasn't been working for two days. Any news about that?
Thanks a lot in advance for kind answer.
Regards,
Stefano
Hello,
          You can now download the ZEISS INSPECT software on the ZEISS portal.
https://portal.zeiss.com/download-center/softwares/imt/software/620351[PG]
However there is only the last three versions of the software available to download, 2025, 2023 and 2022.
If you are needing a previous version of the software, you can try reaching out to your local support and they may have the software you are looking for.
I have the official GOM inspect 2019 if you are interesting (old version without subscription).
  • 1 month later...
Hi,
I have a license usb stick for older version of GOM Inspect but I cannot download it anymore, only Zeiss Inspect is available. Where can I find the insteller for older versions?
Hi Mate Novak,
You can find the older version at the following web link under the Zeiss Library . This should cover software versions from 2019 and up to 2023. If you require an even older version, I recommend reaching out to your support provider, as they may be able to source older versions for you.
Best regards,
Hi Mate Novak,
I  stand corrected it a appear they have added most of the older software. but from the library you will need to go to Archives and search the software
tab.
  • 1 month later...
Hello Kyle,
Thank you for the hint. I managed to install the software to the new PC. Now I have a different problem.
First, it seems to work fine, all features available with the sub license key but after a few seconds the software crashes and closes.
I have contacted the local distributor of GOM but they won't support unless we pay. For me it seems this is rather an IT issue but I have no idea how to solve. The same software version works perfectly on the old PC with the usb license.
Hi Mate,
this kinda sounds like you are trying to run older software on Windows 11. Only software versions 2022 or higher is running on Windows 11.
Everything else wont be supported by ZEISS.
Yes, it seems it's not compatible with win11 which we have on the new PC. And our usb stick license key won't work with Zeiss Inspect I guess unless we pay for license update.
Hi,
you could always ask your IT to to get a support version of windows and reimage the PC to 10 or 7 depending on the version needed. or as Steven suggested you may need to move to 2022 and that would require an active SMA on that dongle to request a update to the newer License version.  I have attach the tech guide link that covers windows compatibility.  ZEISS Quality Tech Guide
