Older versions of GOM Inspect?
I have always used the GOM Inspect 2016 and my company issued me a new computer and now I no longer have it.  I went to the myGom website to download it today and I cannot find any previous versions of GOM Inspect. I was once able to view and download any of the older versions of GOM from this site.  Can I still download the GOM Inspect 2016 free version, and if so, could you tell me where?
Thanks
Hello
Hope you are doing well and good.
Gom doesn't provide 2016 setup file access anymore for GOM Inspect .
On the official website the oldest version whose setup access is available is GOM Inspect 2019 .
Kindly follow this steps to download the 2019 setup ( If interested ) - Suggested Method
hope this work well and sort your issues .
Good luck
Hello Brian,
we provide the installer of the older software.
The easiest way is to go to my.gom.com and go to the software area.
on the left side you can search for a specific version.
Greetings, Ivan
  • 2 years later...
  • 2 months later...
Where is now the Library ...?
Hi Ali,
library.gom.com now redirects to qualitylibrary.zeiss.com, where you can find older versions
  • 1 month later...
Hello Robert,
now this link redirects to a celum space...and hasn't been working for two days. Any news about that?
Thanks a lot in advance for kind answer.
Regards,
Stefano
Hello,
          You can now download the ZEISS INSPECT software on the ZEISS portal.
https://portal.zeiss.com/download-center/softwares/imt/software/620351[PG]
However there is only the last three versions of the software available to download, 2025, 2023 and 2022.
If you are needing a previous version of the software, you can try reaching out to your local support and they may have the software you are looking for.
I have the official GOM inspect 2019 if you are interesting (old version without subscription).
