Can a VAST adapter plate work on a VAST XTR head?
Currently we have a VAST XTR head, with all our adapter plates being XTRs. We use several vertical probes that don't have any rotation positions. We need to buy some more probe adapters as we are expanding more. Is there any reason we can't save some money and purchase VAST adapter plates (Zeiss Part # 600667-9611-000) for the vertical probes? I notice that our master probe uses the reference VAST adapter plate (Zeiss Part # 600667-9602-000), so I would think I could use them for other probes too, right?
The XT plates and can be loaded with the XTR sensor. And Tom the XT plates do work in the XTR holders. What you need to do is underneath the holder there is a adjustable kind of switch that makes you able have your XT plates loaded in the new holders.
Yes, I forgot about that. It is a disc shaped part with pins. Rotate the disc until one of the pins lines up with the slot of the adapter plate.
  • 11 months later...
I need help going the opposite direction from this post. I have a Vast XTR sensor and use a mix of XTR and MT adapter plates. Currently my MSR only has ZCR sockets. While trying to add a MT socket to my rack I only get the option to add a ZCR socket. Is there a way to program both socket types with a XTR sensor?
