Cylinder location on a plane
Yes.
First, you shouldn't tolerance the axis location on a 3d feature. It isn't from the center of the feature, those locations are from the feature-coordinate-system which on a Cylinder is at the top or bottom of it.
You will want to use Cartesian Distance. The Plane will go in as Feature #1, and the Cylinder will go in for Feature #2. If you create the first Cartesian Distance, you can use the transfer format (paint brush) function to build the Cartesian Distance for the other Cylinders.
